Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 81
Thread: Vic Jr. intake ?
  1. #21
    casey23 Guest
    Do you have a link to the George? Thinking of putting proceeds of underdrive pulley toward an intake setup (if I sell it). Would like to read the comparisons.
    I would invest in something else......... There is ALOT of stuff that needs to be bought,fit.made... 400.00 intake... 300-400TB... ( 90mm) Elbow ( 200) Fittings... Pressure regulator....Lines... Throttle cable sucks.. no place for Evap... I bought mine for cheap and i still think its a mess..... I also run a 3200+ stall so no worrys on bottom end pull...
  2. #22
    Mar 2006
    Mesquite
    Prob should just get meth.
  3. #23
    Oct 2007
    weatherford,TX
    hey man r u selling the tbss intake or is it already gone
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
  4. #24
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by 06-crewhauler View Post
    TBSS intake is gone along with the motor
    Hey Moze you asked the other day when are we gonna drop this 370 in....well not this weekend but the next im gonna go pick up some headstuds and some headgaskets next week....you should see this damn cam didnt think i was going to go this big but its a 250/244 .634/.623 114lsa looks like i get my lobe back lmao
  5. #25
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by casey23 View Post
    Eldelbrock elbow has the bolt holes for a 90 or 78mm tb...i can make his stock rails work we have a ton of aluminum up here at my shop to fab brackets with...who needs an evap just turn it off and fittings were down at autozone...
    but yeah Moze just get a meth kit...the stock intake is fine for you....meth allows more boost and makes you a whole lot safer...its like running race gas with low IAT's everything you floor it
  6. #26
    Wow, thats a lot of cam for a 370. It ought to rock for sure.
  7. #27
    Nov 2006
    Mesquite, TX
    you are telling me...i dont have time or money to get new cam speced out and made....looks like i am going up on stall with the 80e swap
  8. #28
    I still have this one laying around...
    Used Comp Cam for turbo applications. 8000 miles. This is an Extreme Energy model with the very aggressive ramp angles and is designed for forced induction only. You will lose HP if you attempt to use this cam in a naturally aspirated engine unless you're running nitrous on an almost race-type engine. Specs are...
    Intake lobe grind #3730
    Intake duration total 289 degrees
    Intake lift .609"
    Duration @ .050" lift 240 degrees
    Exhaust lobe grind #3724
    Exhaust duration total 277 degrees
    Exhaust lift .588"
    Duration @ .050" lift 228 degrees
    LSA 113
    Cam grind serial # is D8917-05 if you want to call Comp Cams and ask any questions about this cam in your application.
  9. #29
    Nov 2006
    Mesquite, TX
    hmm maybe...an LS1 cam will work in an LS2 just not vise versa...let me think about it
  10. #30
    Crossett,Ar
    So without turbos being takin into effect how much more power is the ls2 370 going to put out then your 6.0?
