Results 21 to 30 of 31
Thread: 4.8L to 6.0 Swap I searched but no....
  1. #21
    May 2006
    Waco TX
    Here is what it looks like.
    The old engine is still in the truck.
    Someone told me that there is a spacer/adapter thing on the end of the crank and it can be removed. You can see where there is a line there, will that seperate from the crank?
  2. #22
    If there are threads all the way out to the end of the crankshaft then that is not a spacer.
  3. #23
    May 2006
    Waco TX
    there are no threads. inside and outside of it are both smooth
  4. #24
    well, if the bolt holes are smooth for about a 1/2" deep then it may be a spacer. Only way to find out is break out the hammer and try knocking it off. I've heard there are a few that style, with the removable spacer. Billy at TRTTurbo told me of it and we tried removing a spacer on one he had but it wouldn't come off.
  5. #25
    Mar 2006
    Phoenix, AZ
    Hmmm hard to say. Does the motor have iron heads or aluminum? Looks longer than I remember mine being.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
  6. #26
    Mar 2006
    Phoenix, AZ
    Quote Originally Posted by Red03SilSS View Post
    That doesn't look like a spacer to me....did you get a flexplate with the engine? What did it look like?
  7. #27
    Mar 2006
    Phoenix, AZ
    OK I found another pic of a crank with a spacer attached. If you can pop that off you should be in good shape, otherwise it won't work.
  8. #28
    May 2006
    Waco TX
    Its not a spacer. the line in the picture is just s mark. Its one solid piece.
    I read on PT.net you can have the old crank shaved down by a machine shop. is this true?
    also how much do I need them to shave off so it will make it work for a 60e.
    And Thunder
    It didn't come with a flywheel.
  9. #29
    Mar 2006
    Phoenix, AZ
    I've never heard of anyone shaving down a crank, but that doesn't mean it can't be done. Shaving it down will require pulling it from the engine. If you're going to pull the crank anyway, I personally would just look for a newer LQ4 crank with the shorter snout and swap it out. You're going to need new main bolts and main bearings either way.
  10. #30
    May 2006
    Waco TX
    The yellow lines show where the flexplate will be mounted up against. The red circle shows what the flexplate goes around. The inner circle protrudes exactly 1/4 of an inch. Are yall sure this will hit the torque converter? It just doesnt look to be long enought to.
