truck wont start
i just finished my all my wiring and the truck wont start. all the relays are clicking the fuel pumps is working the injectors aren't clogged. if i spray starting fluid in it and crank it it sounds like fires 3 or 4 times and then nothing. i pulled the plugs and they're wet and smell like gas. however when i cranked it with them out i didn't see any spark. but every time i crank it it looks like a little bit of smoke comes out of the manifolds. im at a complete loss here i had vats removed in the tune. if i turn it on the the throttle body opens and closes like it should so that means the ecm is working right (its dbw). any thoughts on anything i should check im really at a complete loss here.
- You may not post replies
- You may not edit your posts
