Hey I have that Flowmaster if you just need something on thre til you get the turbos done.
76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
Magnaflow still makes an X'd muffler, they are like $112.
jees ,thats weird i have dynomax straight throughs,and love em .i dont know the series but they look like a flowmaster shell,welded case ,and sound awesome.i never ran those cause everyone always said run straight throughs for performance.idk.mine sound alot like flows.but then again sounds like youve already made up youre mind.
His is the combination x-pipe/muffler, straight through inside the chamber, not quite like the Flowmaster styling.
yeh mine arent identical to flows ,the shell seems to be like a flow tho.welded case , not tin,thicker than his for sure.im glad i didnt buy the 1 with the x.
