The fact that this is happening after a minute or so...wouldn't this be a open/closed loop issue? Like the O2 sensors aren't sending the correct signal? Just a thought...
You've got plenty of help here on the board so I'm sure we can figure it out pretty quick. How ong did the motor sit before the installation? Injectors have a tendency to stick from sitting long periods of time.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
But even after I get the diagnostic port hooked up what will I read it with?
Tired ol' 5.7, 5.3 swap in progressHandle every stressful situation like a dog.If you can't eat it or hump it.Piss on it and walk away.
You'll have to borrow a scanner or buy a cheap one to read the codes. I've seen them for under $89.00 at AutoZone. They might even let you borrow one.
97 GMC, 2002 LS6.
What MAF are you running?
97 GMC, 2002 LS6.
What you mean tapping them? Taking them out and tapping them or in the truck?
