exactly
I asked nitrous but didnt get a reply, how would a five terminal relay sense a voltage drop or load and initiate one terminal over the other 87 vs 87A, how does that work?
exactly
LSX conversions, so easy a caveman can do it.
It won't see it unless you apply it. 87a isn't hooked to anything so just forget it's even there, pretend you have a 4 pin relay. 87a is a test point on the relay which has to be applied with an external source of power.
When current flows across pin 85 and pin 86 the coil will close contact 87 to 30.
Does this answer your question?
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
Like r6z4o6 said, I wasn't quick enough.
97 GMC, 2002 LS6.
The 5 position relay would switch off from 87a and on to 87 when power is applied to the coil inside the relay. So it sounds as if the 4 wires is correct on your harness. The pcm is looking for a reason to supply fuel(oil pressure??)
1991 Silverado ECLB
LM7-T56
Wiring schematics are one thing, PCM logic is another.![]()
1991 Silverado ECLB
LM7-T56
Whew I can't wait for this thread to end!Anyway, I hope things work out.
97 GMC, 2002 LS6.
three pages and 28 posts and we have confirmation, the relay was bad.![]()
Omg.
wow!!!!!
Vortec Performance Tuned
Damn, I wish you would've changed out the relay to begin with or just jumper it. The way it sounded it could've been anything.![]()
97 GMC, 2002 LS6.
