Like maybe the power lead that runs to the starter relay has been taken off or the fuse popped?
what year computer did you get?
same pcm out of the 03
1996 GMC extended cab, 2003 5.3/auto
On my '96, I wired the large yellow coming out of the C-100 firewall connector, to the large white wire in the LS1 harness, that called for keyed 12 volt. BAM! It started.
Well I hooked the solenoid wire up to a big yellow wire in old harness. It would come on when in crank position. The truck would then crank with key, so believe that is figured out.
Then when I pulled a plug to try and see if I had spark, all I get is the starter solenoid spinning.so it looks like I'll be getting a starter tomorrow.
The plugs didn't look good either so will go ahead and replace those as well. Could be the culprit for it not starting.
Yes replace that starter and slap in some new plugs.
If fouled plugs dont fix it, I have the solution, just gimme a call...
LSX conversions, so easy a caveman can do it.
ok so now it will crank fine with ingition key. But not getting any spark. Is there kind of test I can do on the ignition coils? I've tested and am getting power and ground to the wires to each side of coil packs. The relay to nelson wiring is clicking at was told it should be. Everything now has a good power and ground but no spark.
Any ideas to what to check would be great. Do these engines have any kind of module like the ones with distributors have? That would cause it not to have spark?
It sure sounds like VATS holding you up. Do you have access to someone with HPTuner software that can download your file and see if the VATS is turned off?
There are two other things can can be holding up your spark, one is the cam position sensor on the top of the shortblock at the back behind the intake manifold, the other would be the crankshaft position sensor on the passenger side of the block around the starter location. If either are bad, not connected or have bad or broken wires the engine will not fire. I pinched the cam position sensor wires between the block and transmission bellhousing once and the truck wouldn't start. I then had to repair the wires since they were smashed beyond recognition when tightening the bellhousing.![]()
