Ok i just have one question. I thought the stall was really hard to pull on and off? This is the reason why i dont want to try to install my own stall. Does it just slip on/off easly or atleast able to pull it off with your own arm strenght? If it does then i might actually have a stall before SAR!
Would you have any tips on a stall install/removal?
Thanks, Brandon
04 Silverado RCSB
02 LS1 Shortblock(Stock)
LS6 CAM - 204/219 .551/.548 117.5
243 Heads w/ Light Weight Valves
Exhast- LT Pacesetters w/ory, 3" Straight pipe
Suspension- DJM 4/6, Doetsch Shocks, Caltracs
Need a ported DBW TB > http://www.ls1truck.com/forums/sale-...ale-trade.html
That's a confusing post. Refer to the part as a converter or a TC or something so we know more about what you mean. Even a smaller diameter (higher stall speed usually) is still weighty. There are about 3-4 "clunks" it has to make going on the be installed all the way. Don't get it on the trans all the way and you'll shatter the pump when you tighten the bell housing bolts (ahem....ask a couple users here). Always make sure the bell is all the way against the engine AND the TC is free to rotate before installing the bell housing bolts or TC to flexplate bolts.
^^^Like he said, to change out the TC, you need to unbolt the bell housing, pull it all the way off to get good access to it, and always make sure its completely seated correctly
2002 Z-71 ECSB-FLT Level 4, 6" Fabtech, 35's, all bolt ons
1998 Cherokee, 4.5" lift, 31's roof rack, ARB bumper
that truck looks familiar where have i seen it lol. nice writeup man, you missed out on all the fun with my motor swap
72 C10 5.3 4L60E
