ok so today i got a little more work done. got the pedal mounted...well kind of...i put it in the stock location but theres only 1 bolt holding it in. gotta figure out how i can get the second bolt in there. heres some pics tho!
Wow your getting closer
Good build thread!
When are you putting the headers in? Im curious to see how the fitment is with the 4wd
Is there an o2 bung on them. did u get them off summit? and do you know the part number for them?
That would be awesome. I wasn't going to go with Shoenfeld because a lot of people complained about the fitment issues in 4x4s. I was just going to run manifolds but now im thinking Ill do those pacesetters. Do you know what exact application they were for, or were they for this specific swap
part number 70-2265. they are for 99-06 fullsize chevy. yea the schoenfeids will not work with 4wd at all. they dont clear the front differential. only downside to them is the coating. i would definately suggest hetting them coated because mine are already showing some surface rust.
