Don't mean to threadjack, but does yank require different bolts rather than the stock ones?
Ugh - I'm tired. I thought this was the Ardmore thread.![]()
i have all the stuff to get my truck going, but might not make it now.... well is drilling slow.... but on the up side, will prolly have twins by the next meet......
single digit street truck
for build info
I might head out there. Might be the only Caddy out there. Been wanting to see what it runs in the 1/4. It will be slow.
Dave, some Yank converters require you to use 1/8" washers inbetween the converter ears and the flexplate. If you do not do this, when you bolt up the converter--either the converter flops around and bangs against the flexplate or you pull the converter too far off the hub and the pump seal is not solid and you can burn up the pump.
I would recommend using RTV or a type of glue to set the washers on the flexplate--cause if hyou don't do that, it will take little fingers to get in there and put the washer inbetween the converter ears and the flexplate--while trying to get the bolt on...
