Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: start up please help
  1. #11
    Jan 2006
    Don't feel bad, we have guys from Kentucky that can't form an intelligent sentence.
    That's funny as hell Red!
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
  2. #12
    Oct 2005
    Baton Rouge, LA
    i test the pcm of 1999 chevy truck in a2000 truck and didnīt work
    the engine doesnīt start only the full pump and the engine crank
    why?????
    Odds are, VATS is still enabled on the PCM. I had that problem when I first started my project, and the engine would crank over-and-over, but not run. It'd seem as if it'll start, but then die less than a second later. Get VATS turned off, and you should be good, as far as turning the motor over to run it.
    ..i need to run the engine to make a buggy i have all the 4x4 system
    Help us understand what it is you're looking to do with this setup. Will this be a street vehicle or an off-road vehicle?
    If it's off-road, there's a good deal of things that can be disable on the PCM:
    1. VATS
    2. EGR / A.I.R.
    3. Rear o2 sensor delete
    4. COT disable
    ... and more
    If it's a street vehicle, then depending on environmental restrictions, some things may still be required. However, as stated in previous posts, I'd start with disabling VATS, and work from there. PM "farmtruc" (Allen - Nelson Performance). He can take care of what ya need done. Shyt, he can even help ya with a lil extra if the price is right for ya.
    BTW, there's not much room for frugal-ness when it comes to customizing. Best of luck.
  3. #13
    Jul 2006
    i only want to run the engine, but i donīt have the instrumental cluster and the computer below the column (bcm)(auto theft) is posible to run the engine? i have the complete wiring
    the pcm control the automatic trans and the front diferential???
    i only want to run the engine, but i donīt have the instrumental cluster and the computer below the column (bcm)(stolen) is posible to run the engine? i have the complete wiring
