Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: motor mounts
    <div class='quotetop'>QUOTE(c1500 &#064; Apr 28 2006, 12&#58;48 PM) [snapback]51534[/snapback]</div>
    so these motor mounts would be the right ones to bolt a 2001 lq4 into a 91&#39; full size right...?
    I started with the flat plates they show there, and bolted regular SBC brackets to them. Not a perfect fit IMO. It puts the end of the trans and the motor 15mm (a little over 9/16") further forward than it needs to be. I re-made the flat plates with the additional offset, and everything fits perfect, driveshaft is dead nuts to how it&#39;s supposed to be. My truck is a SCLB, so it has the longest 1-piece driveshaft. I did not want to loose any slip yoke engagement, so I went the extra mile (or 15mm in this case) to get everything spot on.
    If you do not have the tools to fab your own though, these would be a decent start.
    Anybody able to run the block mounted AC with these brackets? It won&#39;t fit with mine, 15 offset or not.
    Mike
    http://kds-performance.com
    94 Silverado Z71 SCLB 4.8L LR4 Daily Driver
    93 GMC Sierra 2WD LS V8 Swap dun, run, rusted, stripped & junked
    1979 Caprice Coupe - LS Swapped - 11.76@115.8
    Jan 2006
    I think so but I would talk to Summit before you bought them.
    To use the stock a/c you have to notch and box the frame for clearance.
