<div class='quotetop'>QUOTE(Jewmont3 @ Mar 26 2006, 06:50 AM) [snapback]48323[/snapback]</div>
That would help weight balance as well. So everything work out ok then?
Everything worked out perfect. The trans output seal matched perfectly to the mark on the yoke. Trans mount also lined up perfect. Using all stock off the shelf parts for the entire swap on the truck. Only thing custom made were the motor mounts.
Old: 1998 K1500 White ext cab stepside, vortec 350. Stock besides Volant intake.
New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, '02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
