Results 11 to 20 of 24
Thread: Think I've hurt the little 5.3
  1. #11
    Sep 2003
    Man this sucks to hear,hope you get it figured out.I am curious also what it is,let us know bud
  2. #12
    Jun 2005
    I am 6.0 shopping today. Found a 04, LQ4, 9K miles for $1500.
    Hey man were did you fine that at, is it just the longblock or complete motor thats exacly what I'm lookin for..... Thanks 6.0L
    2002 Red Chevy RCSS (engine mods)- 05 5.3L, Procharger P-1SC 9lb.pulley, 80mm BBK TB, TB By-Pass, 38lb. Inj., AlkyControl Meth Kit, ASM L/T's, Magnaflow X-pipe, Borla's, FLT Level 5 4L65e, PI 3000 Stall, B&M Tranny Cooler, 3:73's, G-80, E-Fans, 160' Thermo. Custom Built Intake with K&N. WideBand 02 Sensor, DIXIE TUNED.
  3. #13
    Looking at the photo above, is that a performance mod on the alternator? Do you gain 5HP if you flip the fan belt upside down? I'm gonna have to try that mod sometime.
  4. #14
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Feb 18 2006, 02&#58;31 PM) [snapback]44804[/snapback]</div>
    Looking at the photo above, is that a performance mod on the alternator? Do you gain 5HP if you flip the fan belt upside down? I&#39;m gonna have to try that mod sometime.
    good eye red&#33; i think the belt tensioner is broke and thats one way to take the slack out of it&#33;
  5. #15
    Aug 2005
    <div class='quotetop'>QUOTE(Bad_Apple &#064; Feb 18 2006, 02&#58;17 PM) [snapback]44802[/snapback]</div>
    I am 6.0 shopping today. Found a 04, LQ4, 9K miles for &#036;1500.
    Hey man were did you fine that at, is it just the longblock or complete motor thats exacly what I&#39;m lookin for..... Thanks 6.0L
    Complete motor. I&#39;ll have a lot of extra parts to sell and soften the cost.
    Davis Salvage in Corbin, KY. Found it through car-part.com. They had 2 other 6.0. 1 more LQ4, mileage unknown, described as scorched. Looked at it but passed. Worried about seals and gaskets. They wanted 1000 for it. They also had an LQ9 with 60 something thousand on it. Wanted 1850 for it.
    I grabbed the belt and spun the motor to make sure it was free. Flipped it when I did.
    I&#39;ve driven the truck a bit over the last couple days. The darn squeal is gone replaced by a steady tap.
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
  6. #16
    Feb 2004
    Western, KY
    Check your waterpump, mine kinda did what you are describing except it broke the impeller off.
    Mods:
    Maybe STOCK
    "My lugnuts require more torque than your ricer is ever going to produce"
    Sleep: That Stuff Is Overrated
    "You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
    Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
  7. #17
    Aug 2005
    <div class='quotetop'>QUOTE(ULuze2 &#064; Feb 20 2006, 05&#58;06 AM) [snapback]44904[/snapback]</div>
    At some point in my checks I removed the main serpentine belt and the A/C belt and fired it up. The noise was still there.
  8. #18
    Aug 2005
    I supose this is what was making the squeal. The squeal quit after awhile replaced by what sounded like a ball bearing bouncing around in the engine. I think when I pull the lifter it will be rough and was probably making the ball bearing sound? Lots of talk on other boards about this cam manufacturer and possibly a bad batch of cores. Just the one lobe. Guess I&#39;ll get a bigger cam now.
  9. #19
    Oh, that ought to be fun. Looks like time to pull the heads and put new lifters in. Here&#39;s wishing you better luck next time.
    You might consider having the cam bearings inspected or replaced, especially around the messed up journal.
  10. #20
    Jan 2006
    San Antonio
    Man that sucks.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
