Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: 7 wires left then I can start. HELP
    #58 blue is typically green and it's the serial data line from the obd2 connector under the dash board.
    #50 red is a green/wt vehicle speed sensor
    #59 blue is not connected anywhere I have seen before
    #49 Red is not used anywhere
    #48 blue is MAP sensor 5V reference signal
    Are you sure this is a truck harness from a 2000? The pinout above don't match a 2000 PCM in many spots for some reason. Did someone repin this thing?
    go to this website for LS1 wiring harness diagrams and further information.
    http://ls1tech.com/forums/showthread.php?t...002+pcm+pin+out
    Nov 2005
    Purple and the yellow wire are coming from the tail shaft of the tranny .
    Where do I hook them up.
    VSS out to speedo? The 4K right?
    It may be 1999 wiring. Im just going by what I was told.
    SOON TO COME!!!!
