Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Oil Pressure sensor adapter for OBS swap
  1. #11
    Mar 2016
    BC Canada
    That's the same sensor I used. Just went to the local parts store and they had an adapter to make that work on my ls engine.
  2. #12
    Sep 2011
    Quote Originally Posted by rockusaf View Post
    Do you by any chance have the part number of the sensor you used? I've got BWD S4074 sensor and it's way bigger than 1/8 NPT thread. Appreciate the help, gotta get this thing running.
    Rock
    you will need to use the stock stand off as well from your older vortec engine
  3. #13
    Nov 2014
    The engine was a 1991, no vortec, I couldn't find anyone that had anything that would work, picked up Autometer #2268 that is 16x1.5 with an 1/8NPT tapped hole figuring I could drill/tap it to fit the sensor if need be. I'm going to ask a dumb question (seems too easy so it'll probably never work) before I drill a hole in a $13 piece of brass, any reason you can't just tap the tan wire off the stock LS3 sensor to the tan wire going to the gauge and get it to work?
    Rock
  4. #14
    Monett Mo
    Rock
    I just done that on a swap I done for a guy at work. We used the factory ls sensor in his truck and seems to be working just fine.
  5. #15
    Nov 2014
    Awesome, I'm gonna try that first and hang on to the adapter if I need it. I figured it'd be too easy there would be no way it would work. Thanks for the info, I'll definitely follow up if it works.
    Rock
  6. #16
    Nov 2014
    Well the gauge is pegged all the way to the max and it does move some (but not much) when I turn it over but it doesn't reset back to 0, any ideas? Also, seems like the VATS wasn't turned off like it was supposed to be when I had the computer tuned because I tried to fire it and it starts, runs for a second and dies. But it did run so that's promising and with just headers it's loud as hell.
    Rock
  7. #17
    Nov 2014
    Just a follow up, I ended up picking up a brass adapter from the local parts store and drilling/tapping it for 1/2"NPT to get the 98 sensor to thread into the head on the engine, just connected the 1 tan wire to the gauge and it works like a champ. I just capped the orange and gray (?) wire coming off the pigtail and I'll just pull the wires going to the computer since the engine doesn't seem to care if it's not getting a signal.
    Rock
