Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: 2007 4.8 to 2008 4.8
  1. #11
    May 2015
    So far I have replaced the crank sensor behind the starter with the original because the actual plug was different. Also I rewired the cam sensor to the rear. The supposed 07 has the knock sensors under the valley pan where as the original 08 has them on the lower block. I changed them out also. I know those wont not let it start but those are some of the differences. Would the reluctor wheel need to be replaced? Or do I need to replace the camshaft gear because those have different patterns for the sensor to read
  2. #12
    San Antonio, TX
    You are using two different engines. One is gen3. One is gen4
  3. #13
    May 2007
    Oak Forest, Illinois
    The Gen3 engine uses a 24x crankshaft reluctor and uses a Black CKP sensor. The Gen4 engine uses a 58x crankshaft reluctor and uses a Gray CKP sensor. The 58x engine which uses an ECM (Engine Control) and a TCM (Transmission Control) cannot be run on an ECM (Engine and Trans Control) without the Lingenfelter box.
    Jeff
    98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
  4. #14
    San Antonio, TX
    And I'm not sure ling offers a box that goes backwards.
    Gen4 -> gen3
  5. #15
    May 2007
    Gen4 -> gen3
    Hhmmm, I didn't know that. Thank You for the clarification.
    Jeff
  6. #16
    San Antonio, TX
    There was talk and there were a few but I don't think it happened. I looked on the site unless I'm overlooking it
    Nowadays it's tuff to find a gen3 with low miles and I'm not sure anyone would take a step back.
