Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 74
Thread: 1995 C2500 ls1 swap
  1. #11
    Apr 2014
    That will be crazy fun!
  2. #12
    Dec 2008
    South Carolina
    Quote Originally Posted by Skylark View Post
    Thanks I sure hope so!
    Got a good bit done today. Ended up going with 241 heads to lower my compression for boost so had to swap my valve spring kit over. Finished putting the motor together, then got motor mated to trans, and pinned the crank.
    Few pics of the progress
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
  3. #13
    Dec 2008
    South Carolina
  4. #14
    Dec 2008
    South Carolina
    Well the clutch and flywheel
    Set up I have doesn't work so I'm waiting on my RAM 1550 flywheel and RAM powergrip clutch kit to come in before I can set the motor and trans in the truck
  5. #15
    Dec 2008
    South Carolina
    Still waiting on flywheel and clutch to come in....
    Got bored and set the blower on the motor for shits and gigs. Man that's sexy! Need to repaint the head unit tho
  6. #16
    Dec 2008
    South Carolina
    Ram flywheel, ram clutch and a few other goodies came in! I went with the ram 98793 clutch, it supposed to be rated for 600hp. I couldn't get the clutch system to operate perfectly. I ordered a Novak adjustable throw out bearing to get everything in adjustment as it should be. Link to bearing I used
    http://www.novak-adapt.com/catalog/c...t_bearings.htm
  7. #17
    Dec 2008
    South Carolina
    Took the truck to my parents shop to keep it out of the weather. Got the motor set in as well!
  8. #18
    Dec 2008
    South Carolina
    Since I'm waiting on the adjustable throw out bearing to come in I moved on to another project on the truck. Installing the Walbro 255 pump
  9. #19
    Dec 2008
    South Carolina
    Well got the fuel pump put in. I went with an edlebrock kit that used the gss340 pump. It was a direct swap and the only modification needed was a piece of high pressure submersible fuel line. Pics of the progress
  10. #20
    Dec 2008
    South Carolina
    link to fuel pump kit. Not sure if this is just a walbro pump with an edelbrock name, but it was a direct swap into my oem bucket.
    http://www.summitracing.com/parts/EDL-3581
