You'll have to use the flat 6.0 flex plate with a spacer and probably elongate the torque converter holes. Thats the only way that trans will work behind the ls engine. It's cheap and easy. Factory a/c is easy to keep as well, not sure what compressor your truck has but there are kits out there to keep it. I used dirty dingo DD2550C mounts. Worked perfect.
