Results 11 to 20 of 24
Thread: 68 c/10 5.3/4L60e swap "Project Black Cherry"
  1. #11
    Oct 2013
    Thanks a bunch for the response Slick68, I appreciate that. Seems a little hard to get some feedback on this site unless you're a member with some time. Either way I appreciate the advice and will look into those sites. I'm like a teenager with his brand new veh with this truck, or at least that's how i feel. I personally don't like the way the radiator fits either. It belongs to a friend that supposedly ordered it for a customer of his that is also doing a swap. I'm not sure why he ordered it with those dimensions cause it seems to fit funny. I will most likely order a boyds custom tank as well since i am wanting to run an internal pump.
  2. #12
    Oct 2013
    Got my new radiator support, but the radiator I got from a friend doesn't really fit that well, I'm kinda thinking about buying a RnD radiator and shroud kit, but they sure are pricy!
  3. #13
    Oct 2013
    Got some more parts for the truck.
    I could've sworn that these came with the led boards as specified when I placed the order but no luck, I'll have to call Fesler and double check.
  4. #14
    Oct 2013
    Some more goodies arrived.
    Alper Motorsports billet 3bolt to 4bolt TB adapter
    New GM 90mm ls7 style Throttle Body
    Lokar flexible aluminum trans dipstick
  5. #15
    Oct 2013
    I'm having an issue with the bottom of the 90mm tb hitting the neck of the water pump, need some advice as to what you guys would do in this situation?
  6. #16
    Mar 2013
    Long Beach California
    i have that lokar dipstik too. nice looking piece but damn its pricy huh!! i thought oh well, it looks great! well after its installed, who can even see it!!?? haha oh well, live n learn.
    anyway, i havnt done this myself but ive heard of guys heating up the neck with a torch and twisting it so it faces forward. i think that was to clear the AC pump bracket for guys who mounted it up high on the passenger side. not sure if this will help you or not. maybe you could look and see if that would work or not. if not, all i can suggest is looking around for a 90 degree neck?? dont know if they make one. just a thought.
    one last thought i just had, i think car accessories are different than trucks so its possible the ls7 (corvette right?) had a different water pump that put the outlet in a different location??? look into that. but then you might have issues lining up the pulley... good luck!
    CALI LEGAL ENGINE SWAP!
  7. #17
    San Antonio, TX
    Pull out the neck and weld on a shorter one?
    Redrill plate and tap for new holes; crook'd throttle body lol.
    Camaro water pump, which is probably the easiest; but more cost, what the hell it's just money.
  8. #18
    Sep 2012
    Quakertown, Pa.
    Looks like the neck needs to be rotated clockwise to clear the TB. You can heat the water pump with a torch and place a wooden dowel or handle inside the neck for a lever. I have done this to clear my A/C bracket. It worked like a charm.
    John
  9. #19
    Mar 2013
    just found these pics in the thread next to yours where the guy is asking for pics of wire harness routing. looks like the do in fact make a different water pump.
    http://i22.photobucket.com/albums/b3...1/DSCN1720.jpg
    http://i22.photobucket.com/albums/b3...1/DSCN1719.jpg
    his username is rpm graphics. shoot him a pm. I'm sure he could tell u what it's off of.
  10. #20
    Sep 2012
    Quakertown, Pa.
    The pics 'Jay are referring to are of a water pump from the Camaro/Corvette, or any other LS powered car. I believe only the trucks and SUVs came with the top water neck.
    John
