Originally Posted by
rlmclaughlin
There are two different type of propane systems, liquid and vapor. If it was a vapor system power would be about 40% less however with a liquid system like mine its about the same power as if u ran premium gas, as liquid propane is the equivalent of 110 gas
Plus if you are injecting liquid propane into the combustion chamber, as it changes phase into a gas from al liquid, the charge temp goes way down, allowing for more power.
peace
Hog
97 GMC 2wd RCSB 5.7, s10 2700 footstall, Hooker 24621hkr LT's , 2.5" cats dual 4"pipes exit B4 pass. side tire, custom driveshaft 3.42 G80 FIPK MAF descreen GM/Mercruiser Marine intake manifold 29lb LS2(EV6) injectors Ed Wright PCM(best mod), LT4 KM 14.8@94mph 2.007 4000lbs 122mph
