As far as the 5.3 truck intake, does anyone know or have diagrams as to where the vacuum lines connect to? Again, my swap is an '02 5.3 DBC into a '94 obs.
what vac lines are you reffering to? afaik, there is just the one on the back for the brakes.... which im pretty sure is blocked off due to the hydroboost... but if your running vac for brakes, then all you need is the nipple to replace the plug and run your stock hose from booster to the back...
CALI LEGAL ENGINE SWAP!
