Results 1 to 10 of 11
Thread: options on A/C brackets
    what are my options on running A/C on my truck? i have 02 LS1 (f-body acc.)
    i see a couple companies that make brackets for different compressors.
    does anyone have a list of all the companies that make A/C brackets? i'd like to weigh all my options before buying the first one that i find.
    Sep 2011
    What year is your truck, what compressor are you wanting to use?
    my truck is a 96. i guess now the question is which compressor is better & easier to hook up to my truck.
    i see some mounts are for the R4 compressor & some are for the sanden compressor.
    i tried to contact josh powers about his bracket but he hasn't returned my emails. so far it looks like the dirty dingo if i go with the R4 compressor or the Kwik bracket if i go with the sanden.
    Sep 2011
    Here is what I am in the middle of on my swap, I need to get my neck on my water pump fixed
    http://www.ls1tech.com/forums/conver...e-answers.html
    May 2007
    Oak Forest, Illinois
    Quote Originally Posted by RPM Graphics View Post
    I sell a bracket kit to mount the stock compressor and lines in a 96-2000 GMT400 truck.
    Jeff
    98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
    i have an true LS1 so i have the f-body accessories. looks like your bracket is for the truck motor/accessories correct?
    Sep 2011
    I am liking that setup better than what I am trying to go with, does your bracket include the alternator bracket too?? What is that tensioner off of?
    Jan 2012
    Im using the dingo mount. I like it.
