So closer to a 3600 thanks. Along with that I need a deeper Trans pan and Trans cooler right? Any particular brand or anything on the cooler? Does anyone have any dyno sheets showing their HP with a similar set up that I'm going with?
No the stock pan is fine, but just get a tru cool trans cooler 40,000gvw, just google it should cost 118$ I had a similar set up made 341rwhp.
Bro, do some reading in the performance mod section of this board. It WILL answer a majority of your questions. Not tryin to be a dick, but do some research and if you still don't understand, ask some questions. In short: bigger cam needs a higher stall. Gears would be beneficial as well as a trans cooler so you don't fry your trans. Are you planning on building the trans to handle the power you want to make? Also, budget plays a lot into what you can and "should" do for mods.
Remember you can have only two of three things: fast, reliable, cheap
- You may not post replies
- You may not edit your posts
