Page 2 of 18 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 178
Thread: 94 Lifted Silverado 6.0/4L80e swap Build
  1. #11
    Jun 2009
    Caledonia, MI
    Gas tank has been dropped out, ordered a new one while I have it out. Also ordered SLP Loudmouth 3" exhaust, Edelbrock 3581 266lph fuel pump, -6An fuel filter. Just waiting to get the new parts and Ill swap in the tank, then Ill be able to move onto the motor and tranny. While im posting, what do you guys suggest for a cam. Id like it choppy, but i plan on sticking with stock heads for now.
  2. #12
    Jun 2009
    Caledonia, MI
    SLP Loudmouth exhaust showed up today!
  3. #13
    Nov 2010
    Durant, Ok
    Tr224
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
  4. #14
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by scarybowtie View Post
    Tr224
    Isn't that cam considered a little small for a 6.0? I saw that on another forum. Is that what you run
  5. #15
    I used a circle d 2800 converter and its perfect, and I still pull trailers all the time. I also used ls1 f body fans, they were easy to mount. Does your lq4 have return style fuel rails?
    do you have any pics of how you mounted the fans?
  6. #16
    Nov 2010
    Durant, Ok
    Quote Originally Posted by HPICamaroSS View Post
    It's what I will be running. It depends on what you will be doing with the truck. I don't consider it small for a lifted full-size truck. I've seen a lot of guys using them and they make good power, but will still have good manners for a truck. And you won't have to have a 3500 converter to get into power
  7. #17
    Nov 2010
    Durant, Ok
    Quote Originally Posted by RPM Graphics View Post
    It's nothing fancy but I will try and get pics today. I trimmed the backside flat and the top it bolted to the top lips on the radiator. It cools excellent and I've put 10k miles offroading included and never had issues
  8. #18
    Jun 2009
    Caledonia, MI
    fuel pump hose help
    Been trying to install the new fuel pump...that little 3 inch hose that i replaced is being a pain in my pee hole. The new hose i got fits fine over the actual fuel pump, but where it connects to the tank line, its tight as heck. I have tried grease and pb blaster and nothing has helped it slide all the way up. i can only get it on a quarter of the way. any suggestions?
  9. #19
    Spit on it.
  10. #20
    Jun 2009
    Caledonia, MI
    Spit on it.
    Huck-A-Ta-Poey
