you never know with driveshafts. i've seen stock ones break at 100mph with 3.42's and some live up to 140mph with 4.10's.
GM's driveshafts aren't meant to spin as fast as we make'm, hence speed limiter. Yes there are many out there going past the shafts critical speed, but you never know until you try it.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
ya true... maybe ill have to look into a aftermarket one if it does?
Built 2 Run! 6XX HP/ 6XX TQ
i've used a lot of different companies and i haven't had one failure with http://www.driveshaftspecialist.com/
they made the one for my track truck and after they made zach's 5" (4.56gears w/ 6speed auto) with no vibe and no failure, that's proof enough for me.
Nelson Performance
NP on Facebook
Youtube Channel
Thanks for the warning, hopefully I won't reach the limit of driveshaft.
With the 3.73's I was turning about 2100rpm's
Also my drivers side wheel speed sensor is leaking, could I just pull it out and use sealant? any other ideas besides replacing?
