I think they should fight it out in the ring.
Lil Sis went to Tamaulipas and Parish's truck went to Sinaloa, I think they are over 15 hours away from each other.
2007 RC Silverado aka ?
1998 Trans AM aka Red Dragon
Yes parish truck was sold years ago, and there's plenty of flaco street racing.
theres a big difference between the two trucks mentioned. Parish's truck was a true street truck on 18" wheels on drag radials with stock suspension. Lil sis is setup to run the 1320 and is much lighter then parish's truck was. Parish's truck twin setup was never ran to its fullest as it was sold shortly after the block was cracked. The new setup made big numbers then split the cylinder. New motor dropped in then truck was sold shortly afterwards. I ended up with the cam out of first motor and a healthy cam was tossed in with the twin 72s
if you want to compare the fastest true street truck then we need to bring Jared [stock48] to the plate as he still has the title of that
2014 Xsport- 3.5 Eco boost
412 Motorsports
Like was mentioned Flaco's truck is faster but Parish had a true street truck run any where any time over and over again as much as he wanted. I would like to see Flaco's truck run even three full runs back to back. Props to both as they are both much faster than I. Both are awesome tuner/builders.
412 Motorsports
