Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: measuring cam base circle
  1. #11
    The base circles vary due to lift and duration. They can only cut a lobe so tall before it will not be able to fit through the bearing bores so they get the height of the lift by reducing the base circle.
    But you would assume that givin a grind, they could tell you what size base circle it used. I can see it being different on different grinds, but not on the same grind.
  2. #12
    The Garage
    If it's the cam you bought from me, it jives with stock length pushrods.
    Ok, Thanks Devin. I guess I should have just asked you in the first place Still, I'm trying to get everything right so I'm being a little careful
  3. #13
    The Garage
    Oh, one other thing. My friend just put the texas speed torquer V3 cam in his GTO. it's a 64X lift cam and based on what I'm reading, I'm thinking he might need longer pushrods. Suggestions?
  4. #14
    Same thing. Measure the base circle and compare it to the stock cam.
  5. #15
    Do the contact pattern check on the valve tip and center it with an adjustable pushrod. measure it and order new pushrods or lock down the jam nut and send it to comp and have them make you a set to match.
