Results 1 to 10 of 18
Thread: might have killed a performabuilt, any sugestions where to start?
    Oct 2009
    huntington indiana
    ok, i was showing off and matted the avalanche from a stoplight on the highway. i went through 1st and hit 2nd and then it jerked then a BANG!. i instantly looked in the rear view to see if i was throwing parts or fluid and saw some s@%& flying out (no fluid), i looked at my gauges and it was reading battery not charging, the truck was still running fine, i assumed it was accessory related and it was. before i get to that issue, i kept on truckin to try to get it home, "almost" everything seemed straight. i drove about a mile and passed a few cars on the highway then i hit the exit to take me home, i went up the exit and stopped, when i went to take off, no dice, the truck would not move, so i called a friend that lives close by take me to gather my parts off the road and to pull me home. when i got to where parts started flying i found my new napa belt tensioner broke into pieces and my ac belt. we got the avalanche home and i put the oe tensioner on and fired it up so i could steer it into my garage, when i went through the gears to get to neutral i felt reverse grab, i thought cool im good to go, nope. i have reverse but no forward gears. i checked all the wires and hoses, it was getting dark but i didnt see any thing awry. when my oe trans messed up and i had forward but no reverse, the trans in the truck now is a performabuilt lvl 2 pro race, with reverse and no forward gears. any suggestions?
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Oct 2009
    huntington indiana
    also, the trans has been 100% no issues at all. the trans was running about 120 degrees, fluid level was perfect, about 1500 miles on filter/fluid, when things went bang i was running between +/-55-5800 rpm and now when its in gear i can hear a humming sound.
    Jan 2011
    Mcalester,okla.
    you broke ur forward sprag or sun shell,thats what the bang was,pull ur trans pan beat u got metal in it,its not a bad break all ur clutches should b fine, just need a new hard part
    Oct 2009
    huntington indiana
    $300 for shipping and performabuilt gives me a new one, what about the other stuff breaking? just a 1 in 1 million kinda deal?
    Arizona/Utah
    Quote Originally Posted by st8kfinger View Post
    What gear was your shifter in when you launched? D or 3rd?
    Oct 2009
    huntington indiana
    was in d
