Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: how does this build sound?
  1. #11
    Jan 2011
    so is this engine going to be able to mate up to a 4l60e than? what years do they consider early and late models? like the 99-2000 are early or what?
    97 s10 for beater
    99 nbs ext cab 4x4 4.8 performabuilt level 2, 3.73s
    lq4 sitting in the garage...
  2. #12
    Early models are 99-2000, they'll have iron heads. There's a few compression calculators on the web, you'll need the combustion chamber cc, I don't know 317's off the top of my head but someone here will and hopefully chimes in. Then you need the compressed thickness of the head gaskets and how many cc's the dish in the piston adds or takes away and it will give you a pretty close estimate at your compression. If it was my build for a dd I'd go for a compression ratio in between 9.5:1 and 10:1, something a little bigger than the LS6 cam, around the 220 duration mark maybe, a nice set of dual springs like the Patriot Extremes and the fuel system to match. Try to keep it around 12 pounds and it will live a long life stomping most anything on the road.
    Jan 2011
    thanks for the input. i looke around on here for a week reading before i posted anything there is just so many opinions.
    97 s10 for beater
