LS6 going in a '99 RCSB
Ok.. finally picked up a motor for my project. It's a '04 LS6. I have the motor, acc's, PCM and harness. Ordered my oil pan, dipstick, tube windage tray and frame mounts.
Next question I have is related to DBW vs DBC. The 04 LS6 has a DBW TB. What is the best/cost effective solution here? Should I go with a DBC set up and do away with the electronics (if it can even be programmed out of the PCM) or should I get a DBW pedal and TAC? I found this one on ebay but not sure if it would work with what I have. http://cgi.ebay.com/ebaymotors/03-Ch...#ht_571wt_1097
Thoughts? Suggestions?
Guess I should call Nelson too... he will doing any and all wiring/programming for sure.
- You may not post replies
- You may not edit your posts
