just becomes another load after the initial discharge, great marketing item for manufactures cause people like to buy em....truly no need for or benefit from them.
2011 4x4 6.2 Silverado ltz 6" fabtech lift 20" XD spy 35" nitto mud grappler
99 Silverado 1500 4x4 RC 4.8
4L60E, 3.73, Homemade CAI, 92oct Quik tuned,08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
One day people will awake to the advantage and use of the cap in car audo. Most just don't truly understand its place and purpose of use.
2001 Tahoe LT Auto-Ride, 5.3 (Soon to be 408 stroker!!!) Newly rebuilt 4L60E!!
Things previously stated are correct. Upgraded electrical is priority number 1. I have no dissagreement and completly agree. But, the view of the cap being a throw away, needless piece of junk is slightly scewed.
The cap has its place in realm of Sound Quality, and is sole purpose is stability. Not stopping light dimming, not acting as another battery, and certainly not being the only upgrade needed. Its only job is to level out and stabilize the incoming voltage signal from the battery(ies).
Any unfiltered electrical signal, wether it be DC from a battery of AC from an outlet, is going to be "dirty" that is the signal will have peakes and vallies. When a cap or other stabilizing device is used, it eliminates those peaks and vallies, giving a more clean signal to the amplifier. This in turn allowes the amp to produce a stronger more level signal to the speakers, lowing distortion and increasing the quality of the sound.
---- One more thing, when a Cap it used, it must be of a proper capacitance. If you put a 1 farad cap on a 2,000 watt amp, that is pointless.
