Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: LS Fans ???? plus problems
  1. #11
    Mar 2008
    Denver, Colorado
    ok so i checked everything out it is all hooked up right. checked on another vehicle we did but it is a 2001 the pin 33 on this computer is actually pin 43 the A/C clutch compressor with everything hooked up they still do not work but i did as you suggested and grounded it and it worked just fine with the switch in the scanner. so i am guessing i have a bad ground in the PCM? i am stumped on this. i guess i can just hook up a switch for just the high speed IDK like i said i am stumped. any help is greatly appreciated thanks everyone
  2. #12
    Broken Bow, OK
    Quote Originally Posted by littless View Post
    Not sure what you were saying there, can you elaborate?
  3. #13
    Mar 2008
    Denver, Colorado
    pin 33 is actually different on different years. the 2001 it is actually pin 43 the A/C clutch request which is what i am asuming turns the high speed fans on. no matter what i try it will not work until i ground it staight to ground. this has been a common problem for us here at the shop we can never get the high speed side to work. some have suggested to just run 2 relays. the low speed keeps the vehicle cool with no problems but it is not right and i need to figure out what i am doing wrong i am just that type of a person
  4. #14
    Broken Bow, OK
    That is your problem right there. You don't need to use the AC clutch request, you need the AC recirc which is Pin 33 on the RED connector. I just double checked my factory manuals to make sure. Wire it to this and do the appropriate tune adjustment and it will work.
  5. #15
    Mar 2008
    Denver, Colorado
    THANK YOU THANK YOU THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!
    this worked and worked great. thank you so much for your help on this
  6. #16
    Broken Bow, OK
    Cool, glad you got it working and glad I could help.
