Simple: 408 on steroids!
single digits coming soon!
i bought a airraid throttle body spacer from summit, it was pre drilled for a nossle in both sides of the throttle body spacer, made a nice clean install too.
2001 GMC 2500HD 6.0L 4x4
"Muffler delete, K&N, Diablo programmer, NX150shot, 160* Stat, T.B Spacer"
More mods to come soon!
Take some pics for us.
install is done, nx 150 wet kit, timing tuned at 8 deg advance and fuel 10% rich..110 octane..
started at -4 degrees timing, and went up till it felt like it was working.. checked plugs, looks good. will take pics and post soon..
-8 ???? for 150 shot??.... How much total timing do you have at WOT ???....
not -8 ...+8, ill have to go back and read a log of when i sprayed it last, and see what total timing was, it felt good, didnt get hot, didnt ping knock pop or anything like that..
..i believe i can add and subtract just fine.. i started out on the first spray with 8 degrees REMOVED from the total... i ended up adding 8 from baseline.. does that make more sence now? and its not lean or pre detonating... plugs look fine
and i always run half tank of 110 when im sprayin..
