All of them are compatible? I'm puzzled. I heard just the 80e's with the bolt hole on the top of the bell housing are compatible. It seems there are an abundance of older 80e's (w/o the bolt hole) in my area, but none with the top bolt hole. hmmmm. I would likke to know the answer to this
Originally Posted by
farmtruc
no , you'll need to swap out the output shaft and get a tailhousing.
i'm sure the trans is good if it was running when pulled.
all of them are compatible.
2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
