Yes its the right signal for the ecm. And you take the 4k output from the ecm and tie into a light blue with a black tracer wire for the speedo connection. The easiest place is behind the glove box where it comes out of the drac box.
1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
Yeah the blue with a black stripe is the right one.
Right on thanks for the help i would see if it works but, I had to pull the motor, turns out the motor I bought has a spun bearing. So I'm currently looking for a short block or a cheap long block because I'm pretty sure the machine shop is going to charge at least 1500 bucks
Its been awhile, but the trucks been running, i ended up putting in a new lq9 and got rid of the garbage lq4 i bought. The truck runs great, pulls hard... all my gauges work besides my tach.
Ive got movement on my tach, it says it idles at 100 rpms and when im in the throttle it goes up to 1500 or so.
Right now ive got the tach wire from my new pcm to the wire to my factory tach. I got a 680ohm resistor 1/4 watt with a 12v switched power source. Anyone got any ideas of solutions? Thanks.
Out of curiosity, would your truck happen to be a 2004? NVM, just saw you have a 2004 engine/pcm. Damn, its such a pattern of issues, these damn 2004 PCMs and not able to drive a tachometer.
