Results 11 to 20 of 32
Thread: servo
  1. #11
    The PN of the parts currently inside the 2007 GMT900 4L60e trans is...
    Cap 8642485
    4th apply piston 8642482
    Piston 8642553 and approximately 2.280 diameter
    out cylinder that fits on the piston 8642466
    not sure on the size of a Corvette servo piston. Anyone have one they bought and haven't installed yet?
  2. #12
    Wait, you have a 2009 with a 4l60?
  3. #13
    my 2007 GMT900 had a 60e. Not a 65 or 70 but a 60. Your's may too. Look on the side of the trans and see if M30 is cast on it. Look in the RPO code list in the glove box.
  4. #14
    Bloomingdale Illinois
    Quote Originally Posted by KeJessie View Post
    so is the vette servo we talk about for our trucks the exact same as the stock gm peice out of the corvette? if so what years or even part number would it be?
    Cap 8642485
    Red the numbers on the actual piston and cover are production numbers. Not the part numbers. This is a misconception often found in the industry so I wanted to point it out.
    Here is the number for the vet servo assembly. Vince
    gm # 8642079 for the piston and 8673039 is for the cover.
  5. #15
    Hey Vince, can you measure one of the Vette servo pistons and post what the diameter is so they can tell if the one stock in their transmission is the same as the Corvette servo or not?
  6. #16
    i thought the servos looked different than what this pic shows on this site
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
  7. #17
  8. #18
    Dec 2003
    Azle,TX
    Hows the the tune? I need to retune for the servo when you get it in....so holla!
  9. #19
    great! soften the shifts or what? and welcome back.
  10. #20
    Dec 2003
    Azle,TX
    Yeah...lets see how it shifts and go from there...I may want to make some pressure changes as well.
