Results 11 to 20 of 25
Thread: Rear End Noise?
  1. #11
    you must have a G80 from your description, replace ASAP before it grenades and takes the carrier, gears and transmission with it on its way out.
  2. #12
    Jan 2010
    spanaway wa
    well super.. anyone have an idea for a new gear set and rear end i should buy. i only have 300 bucks left over from selling my other truck, i would like something strong that can handle burnouts, off roading, and extra power from a cam and supercharger. thanks for all the help.
  3. #13
    Round Rock, TX
    It doesn't have the "grenade 80" nickname for nothing!!!!
  4. #14
    Augusta, Ks
    300 wont get you much. 400 will get you a tru trac 600 will get you a tru trac,gears and install kit but then you need to get it installed
    2004 Buell XB12s
  5. #15
    Jan 2010
    spanaway wa
    well this is a problem, what can i do to maybe avoid this rear end blowing up. and can someone send me some links for new rear gear sets, that are cheaper and good brands, how hard would an install be for new a rear end. i have done minor rear diff work on a muscle car, but it has been a long time.
  6. #16
    Augusta, Ks
    Search for Rons machining
    2004 Buell XB12s
  7. #17
    Ha, typical noises from a higher mileage G80. It could be other things, but do what Gavin said and look on the lid of the glovebox for the RPO codes and see if you see G80. You can also look to see what your gear ratio is--
    GU5 = 3.23
    GU6 = 3.42
    GT4 = 3.73
    GT5 = 4.10
    $300 will get you another used G80, but I would try to pony up for the Detroit Truetrac. They can be had for $400. I don't see the need for new gears unless the pinion looks like it has chunks or cracks in it, so just replace the carrier. In some applications, you can get away with using the factory shims, but I would look at getting a new cover gasket.
  8. #18
    Jan 2010
    spanaway wa
    is there maybe a stock rear end i can get out of a junk yard that will stand up to some good abuse, and will fit my truck.
  9. #19
    Augusta, Ks
    It will be cheaper to just buy the tru trac and be done with it.
    2004 Buell XB12s
  10. #20
    Jan 2010
    spanaway wa
    Do you think you can give me a run through of the install, How hard is it going to be, and will i still be able to roast both tires? What are the advantages of a tru trac rear end?
