Results 11 to 20 of 24
Thread: 13 second 2007 nnbs crew cab
  1. #11
    Crossett,Ar
    I honestly doubt you will only turn a 15. A ccsb member at SAR last year pulled a 15.1* with exhaust and tune. Id advise taking it to the track. See where you stand. Id figure you are decently close to your goal. As far as cam choice I would get one spec'd for the charger. Id say that alone with a good choice of stall for your set up would net 13s easily
  2. #12
    Nov 2004
    Pleasanton, TX
    Quote Originally Posted by Chris092183 View Post
    Sambo,
    You don't have headers or a cam? And what is the snowmeth stage 2 kit?
    I have run best of 13.0 @ 102 but I just havent bothered to put up the time slip yet. I just have a turbo @ 10psi, built trans with stall, exhaust, all the necessary fueling mods, meth kit, and a good tune. If you do go to the track you should launch in 4wd, its fun.
    2006 K1500 Vortec Max CCSB 6.0 4.10's, Nelson SD Tune, Trick Turbo kit T76 @ 10psi, 60lb/hr injectors, 4" duramax exhaust, snowmeth stage 2 kit, FLT Level 5 4L70E, Vig 2600, 40K trans cooler, 265/70/17 BFG All Terrains. 13.0 @ 102mph 1.8 60ft
  3. #13
    Gramercy
    my CCSB 5.3/60E went 15.6 with a tune, magnaflow exhaust, LT headers, OR-y pipe. i have a G80/3:42s on 20s
    i added a Circle D 3000-3200 stall, LS2 car TB, 4" CAI an went 14.83@ 94.01 with a lil spinning out the hole. my truck weighs in at 5840 with me in it an a tool box.
    2008 GMC CCSB 6.2/6L80e swap
  4. #14
    Nov 2004
    Pleasanton, TX
    Is it 4x4?
  5. #15
    Schertz, Tx
    My latest run was 12.9 @ 111. Mods are below.
  6. #16
    Gramercy
    no sir 2wd
    theres a guy on pt.net with 3:73s an went 14.3 or so.
    my 4:10s may get me 14.2 or so
  7. #17
    Spring, Texas
    Quote Originally Posted by rutroe View Post
    I have got to teach you how to launch!! lol That thing would easily be mid-12's with a decent 60ft!!
  8. #18
    Gramercy
    Rutroe are you stalling up or just flat footing it out the hole?
  9. #19
    Spring, Texas
    Quote Originally Posted by keniff View Post
    I think Rob is push starting his truck!! With 4wd, a 1.8 60ft should be easily obtainable. The 111 trap is good for LOW 12's if not 11's!!
  10. #20
    Schertz, Tx
    I'm giving it a half-assed attempt to stall it but I basically suck. I agree with Jay...my times would be a little better with a decent 60'.
    BTW, my truck weighs around 5600 with me in it and 1/2 a tank of gas.
