Results 11 to 20 of 30
Thread: 2nd blown tranny
  1. #11
    Dec 2003
    A stock 80e will outlast a fully built 60e and they are cheaper also.
    2000 RCSB forged ls1, 4l80e, t-76
    10.93@124 1.58 60'
  2. #12
    Dec 2009
    Durant
    I was told ill have to change my crossmember and wiring harness and drive shaft is this true or what
    03 GMC RCSB 4.8, Head work by Moon Racing, LT Headers, CAI, TB spacer, E- Fans, Spintech,Built 4L60E,Ultimate servo from TCI,Diablo Sport Tuner ** 4.10 posi rear end, fully built 408 **
  3. #13
    change xmember, rewire the transmission connector and swap to a TH400 yoke. You'll also need a new tune setup with the 80e programming.
  4. #14
    Aug 2009
    Humble, TX
    Quote Originally Posted by tricked03sierra View Post
    If i do an 80e will i have to but the wiring harness and stuff
    You can buy a crossmember for a 80e swap, or just get someone to cut more the center of the crossmember about six inches i think. then weld it with 1/4 metal extensions.
    i dont remember what site but someone does makes an adapter to switch from 60e to 80e, or save the money and do it
    * 2002 Chevy Silverado RCSB w/ 4.3 to 5.3 swap
    Installed: McGaughys full 2/4|HD hood/Z71 Airdam|Circle D Built Trans & 3200 stall|34" fans/radiator|True Trac w/ 3.73s|V8 Swap w/ Milled Heads and Comp valvetrain|Custom Grind 22x/23x Cam|Pacesetters LTs & ORY|Magnaflow|Wheatley Tune
    Future Mods: Paint (Sunset Orange Metallic), milled 243s, possibly a 6.0 with either turbo or procharger
    * 2008 GMC CC Texas Edition: stock with CAI
  5. #15
    Dec 2009
    Durant
    Ok would it be to hard to change to A 5 Speed i found a totaled RST that i can get everything from to do the swap
  6. #16
    Augusta, Ks
    If you want your truck to shift like a tractor then go for it.
    2004 Buell XB12s
  7. #17
    Dec 2009
    Durant
    would it not be better for street racing]
  8. #18
    No. Just stick with the 80e swap. You'll be glad you did it.
  9. #19
    Dec 2009
    Durant
    i was told i will lose alot of horse power when i do the swap and i was told there are alot of electrical problems with the 80e
  10. #20
    Augusta, Ks
    First off. Many have done the swap and their times have gotten better because of the ratios. Second off, even if the 80es had electrical problems think off ALL the problems a 60e has
    60e = Junk
    80e = Reliability and Strength
    2004 Buell XB12s
