Results 11 to 20 of 28
Thread: Lifter Noise
  1. #11
    Spring, Texas
    Quote Originally Posted by 6.0vortecchevy View Post
    I had a problem similar to your, it would only start taping when I drove it hard or i towed somthing. But once I let it idle for a little it would go away. I thought is was my lifters also, but once i changed my lifter and the tap still came i knew it was somthing else. I found that the pick up tube o ring was pinched, So i replace that o ring and now every thing is good and the knock went away. Im pritty sure it the rockers not getting oil.
    That's exactly what it does! I'll pull the pan tomorrow and check the o-ring. I'll let you know what I find out! Thanks.
  2. #12
    Oh geeze. Jay is gunna do his own wrenching? Pssssh...say goodbye to that motor.
  3. #13
    S.A. Texas
    Ouch damn Tyler thats mean, its just dropping the pan. Not open heart surgery. Good luck Jay
  4. #14
  5. #15
    Even if it looks fine go and buy a new one anyway.
  6. #16
    Spring, Texas
    I guess I should have clarified....my dad's shop is going to pull the pan and replace the o-ring.
    Quote Originally Posted by SLO TRUCK View Post
    The one and ONLY time I will say this...Tyler is right, I'm not the greatest with a wrench.. Mostly because every time I need to have something done, a guy at my dad's shop takes care of it while I'm at work or something.
    Yep, got a new one coming to replace just to be sure along with a new dipstick tube. The tube managed to get a hole in it right where the bracket attaches to it and sprayed oil all over the engine bay....what a mess
  7. #17
    Spring, Texas
    Yep, it was the o-ring! It was cracked and pinched! They are replacing it now so I'll test it out and let you know! Thanks for the help!
  8. #18
    Great report back.
  9. #19
    Quote Originally Posted by ramair2002 View Post
    ...Tyler is right...
    AAAHHH, music to my ears.
    It is crazy how many times a lifter problem ends up being something to do with the pickup tube and o-ring...
  10. #20
    Spring, Texas
    I know you don't hear that very often Tyler...
    Yep, that fixed it! My oil pressure is slightly higher at idle and i did several hard runs and didn't have an issue! Thanks!!
