Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Newbie - 5.3 Identification
  1. #11
    Oct 2009
    Ok....now that I have that firgured out I have another hopefully minor problem. This eninge is the "oil pan/axle" version. My assumption is that I remove the axle assy and simply install another oil pan. Could it ne that simple? Is there anything major between LS oil pans I should look for when replacing?
  2. #12
    oil pan and pickup tube will most likely be needed. Sometimes you have to replace the windage tray, too.
  3. #13
    Oct 2009
    Is there a better pan from one to another?
  4. #14
    I like the 99-07 classic truck pan unless you're slamming the truck to the ground then the 98-2002 Fbody pan is lower profile(more clearance).
  5. #15
    Oct 2009
    My book says it's a 5.3 325ci, 9.5 - 10.1 compression, 285-320hp, 325-340 lb-ft.
    Kinda of vague but hope it helps...
