Results 11 to 20 of 23
Thread: Any pics of black stock chevy wheels?
  1. #11
    Plainfield, IL
    I used some of that spray on bedliner crap for mine, cuz they were really corroded when I bought the truck. Super easy to clean...and eventually i just started tire shining them/wheels.
  2. #12
    Spring, Texas
    Quote Originally Posted by lo-lyf View Post
    They really are considering I always thought that was the ugliest wheel gm ever put on the silverado. I have to say that I dig'em in black.
    I bought them from him but still haven't been able to pick them up yet! Hope they still have some tread once I get them!!
  3. #13
    White Settlement, Texas
    Quote Originally Posted by ramair2002 View Post
    Not to be nosey but arent those the aluminum five spoke 16's?.....and your a NNBS which will only fit a 17" or bigger? im just curious cuz i have a friend with and 04' and he wants my stocks when i get my new rims but i told him they're 16's and they wont fit...is this true or no?
    Barks better than it bites......
  4. #14
    Spring, Texas
    Quote Originally Posted by conekiller01 View Post
    They'll fit (shown in sig). Mine came with 16's and is what I run my 26x11.5 ET Streets on too.
  5. #15
    hot & windy
    if i remember right, 05+ is when you have to have 17"s
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
  6. #16
    i believe if you have disc in the rear even in 05 you are fine runnin 16" wheels. i have a 04 and went down to 16s. i had disc but i think if it's drums you can't.
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
  7. #17
    Quote Originally Posted by NorTex4x4 View Post
    Im pretty sure its if you have drums you can go smaller...down to a 15" rim?
  8. #18
    You cant run smaller than 17s on the front after 04-05 because the rotors got upgraded to 1" bigger.. You can run 16s for sure on the back with drums and earlier model disks.
  9. #19
    +1
    +1
  10. #20
    then how the heck did i have a 2004 z71 with 16s on it? it came with 17s and i put 16s on it
