Results 11 to 20 of 29
Thread: what kind of muffler?
  1. #11
    Jun 2007
    Whats the deal with magna flow?I think theyre awfull ,raspy as heck when you get into em,like an old school glasspacks and waay overpriced..ive had alot of different mufflers and magnaflows were the worst.maybe its my setup with f/i and headers size pipes etc,too each theyre own but i dont like a raspy exhaust.Im sure the setup makes a difference and on stock probly wont sound the way mine did.FWIW i like the dynomax ,welded case straight thrus.deep sound stay the same throughout rpm range.Magnas from what i heard was quiet at idle,and raspy throughout rpm range.Maybe dual 2.5s with headers and f/i isnt breating enough through them.If you decide to get magnas ,Ive got 2 like new 2.5 in 2.5 out,ill give ya a deal on,still shiny new.Good luck.
  2. #12
    Bakersville, NC
    Quote Originally Posted by chvy=power View Post
    yea sounds ok when its idling or at WOT but when i'm just easin along it makes that annoying popping sound...
    Ive had flowmasters on evrything and never had what your describing, when easing along?
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
  3. #13
    Who eases along?
  4. #14
    Dec 2008
    South Carolina
    around 2500 rpm when im accelerating it makes a popping sound kinda like my buddies stock truck with knock off glass packs and no cats lol. i hate it but it stops around 3000 rpm
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
  5. #15
    Bakersville, NC
    still have never had that with flows when accelerating, now when downshifting manually its a different story. You could try adding a H pipe.
    David,
  6. #16
    Dec 2008
    South Carolina
    i can't run that cause it would hit the transfer case right?
  7. #17
    Bakersville, NC
    No you just move it on back in the exhaust system. Theres a few around here running them with 4wd trucks.
    David,
  8. #18
    Lawrence, Ks
    I have a 40 series flowmaster, 2 in/2out, and the only time I get any popping is on decel for about a 1k rpm range (like decel from 2500 to 1500 then it stops). But Just cruising or any accel it is great!!!
  9. #19
    S.A. Texas
    go Magnaflow or Borla if you are rich like Moze
  10. #20
    Mar 2006
    Mesquite
    Borla ProXS is Borlas 'economy' priced muffler. It's stainless and build exactly like their expensive line./
