Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Need help connecting my a/c compressor.
  1. #11
    May 2004
    We need to find you a fitting that directs the hoses to the front of the vehicle instead of the side. Let me look and see what we can find you.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
  2. #12
    May 2004
    See how my hoses are facing forward out of the block and 90 out of the fitting back to the drier and go forward to the condenser.
    97 GMC, 2002 LS6.
  3. #13
    May 2004
    Docs Blocks is your best bet with the 90 on the fitting like this.
    Your other option is to go with a 99/2000 compressor with my type fitting.
    97 GMC, 2002 LS6.
  4. #14
    Dec 2004
    San Antonio, TX Area
    This helped me too, thanks.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
  5. #15
    Spiro, Oklahoma
    That 90* fitting still may not clear the mount, it would have to be tweaked a little which could turn out bad since its aluminum. If all else fails I guess I can just go with the older compressor.
    Also I'm reworking a DBC harness to replace my DBW setup that I have now. What,if any plugs of the A/C system can I get rid of ?
    I was told that I can do without these:
    Secondary A/C highpressure switch
    A/C request signal
    A/C clutch relay control
    A/C comp. cycling switch signal
    That would leave only:
    A/C refrigerant pressure sensor signal
    A/C comp. clutch supply voltage
    Does that sound right?
    I found this fitting on docs blocks but it is for the suction side. They have one for the discharge side but the tube comes out of the side. I'm going to email them and see if I can get this fitting in the smaller size.
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
  6. #16
    May 2004
    We could always modify the fitting. I had to machine down my aluminum block for more clearance when the motor torques down on the passenger side.
    97 GMC, 2002 LS6.
