2014 Xsport- 3.5 Eco boost
412 Motorsports
1/2-14 is size of tap
says to use a 22/32 drill bit. this was the correct tap for the barb fitting i used that went from -10 hose to npt
412 Motorsports
your welcome
412 Motorsports
I show the bit size as being 45/64''
Last time I looked at one of those fittings it sure looked like a 89/128 to me... but I was just eyeballing it.
MKader17
Reminds me of a beer game my FIL and I used to play....GUESS THE MICROMETER READING OF A RANDOM OBJECT TO THE 0.00X PLACE. He was better at it but it was fun.
1/2 14 npt drill size is a .719 (23/32)
its a tapered tap so if need be you can ream the top of your hole out a little with a chanfering tool to make the tapping a little ezer. USE TAPPING OIL makes the treads much nicer and you wont get leaks.
Gasguzzler I would like to try that game out some time. Ive been a machinist for 10 years I might do well.
Jeremy
2000 Sierra 4x4 Denali front, 5.3, 3/4 drop, 22 foose speedsters, roll pan, Cold Air, Cat-back.
Ricky's pecker...
0.000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000001
Gone, but not forgotten!
