Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: lil advice please.
  1. #11
    Looks like everyone that leaks is by a bend. Maybe that is why it is not sealing. Due to the contour of the pipe
  2. #12
    Put your hand near where you think the leak is coming from. Do you feel hot air on your hand? If not, move your way up from the clamps to the header collectors. Feel air anywhere else? If not, it could be the gaskets on the block. What gaskets did you use for the LTs?
    And yes, Moze is right--the Pacesetters are kind of thin-walled and have a slightly tinny sound to them...
  3. #13
    It's probably the headers ticking...Pacesetter's are known for doing that...
    Whyyyyy do they do such a thing????
    EDIT: Tyler just saw your post...
    What do you mean by tinny??? Just kinda curious.
  4. #14
    Tinny is a descriptive word of the sound....yet I heard Clifford's headers before I knew what was on it, and they're not Pacesetter brand.
  5. #15
    Does this mean Clifford is tinny sounding or not.
  6. #16
    I know what the word is...I was meaning how does tinny sound? Like an example of something I can listen to to get an idea of what they would sound like!!!
  7. #17
    Winnipeg, Manitoba, Canada
    we use them every day in heavy duty applications, I usually use copper silicone on them before putting them one, seals them up nice
  8. #18
    ff_jeff Guest
    He means the ticking noise (tinny)
  9. #19
    Jun 2007
    ya ,put some high temp on them ,then tighten the crap out of them .Ive had the same issuue and ffixed them that way.i have these all over my exhaust.i personally think theyre awesome clamps.The headers do have a tap to them also.you could use some ball and sockets like i ultimately ended up doing on my header to exhaust connection.flowmaster made the ball and sockets,fyi.good luck ,the high temp should do it for ya.
  10. #20
    Quote Originally Posted by zeake View Post
    Clifford was pretty quiet the last two times I saw him and he doesn't tick per se (like an exhaust leak) but you can tell there are headers present.
