Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Best Transmission Fluid?
  1. #11
    do yall go somewhere to get it flushed or just change it yourself?
    Jan 2005
    Humble/Houston TX
    im with cajun...the el-cheapo stuff. and changing it yourself is easy. if you can pull off a motor swap you can change tranny fluid.
    old mod list: H/C/I/N/E/G 408
  3. #13
    san marcos,tx
    I would just change the fluid instead of flushing it out. Sometimes by flushing it does to good of a job of cleaning it out due to the detergents.Might cause the clutch packs to wear out too soon.
  4. #14
    I wouldn't put IV in the newer ones designed for VI.
  5. #15
    Well DUUUUUUUUH. Put in the recommended grade of fluid...
  6. #16
    Man I just hate putting gaskets on.. I always feel like i am gonna do it wrong. and its gonna leak
    Haha--the cork gaskets are harder to work with than the rubber ones. You can put a small amount of silicone on the pan and stick the gasket to that so that is doesn't move around on you...
  8. #18
    yeah I know. the FLT pan looks so nice sitting there so I dont know if i I want to drop it.
    Ill probably wait till christmas to change the fluid and filter seeing as how it only has like 4k on it
