Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Muffler question from a noob.
  1. #11
    Spintech's flow better than Magnaflow. And Borla's are straight through - how does the Magnaflow flow better monkey?
    Well, for starters, Magnaflow is a straight through design also. And I have seen stats somewhere that prove that they flow better than most of the major Muffler manufacturers. I am not sure if Magnaflow was tested against a Spintech, but I know they flow better than Flowmasters...
  2. #12
    vote for magnaflow here, but do the cat back not just the muffler. it installs so easy and looks much better. and you get a nice tip as well.
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
