Results 11 to 20 of 21
Thread: Front leveling kit question
  1. #11
    pasadena tx
    if you lowering the back to level the hole truck just put the 2' shackle in the back and it will level the truck and they r only 50$
    2004 tahoe new front end shaved gas thank shave rear wiper and handle shaved roof rack hid head and fog lights 22'' vzo wheels all plastic inside painted led back tail lights 5.3 with spacer 373rear end corsa exhaust no cats flash pack programer 150 shot of nos k&n intake.... up coming mods cam, 3200 stall 410 gear and pacesetter headers..
  2. #12
    Kansas
    I did the 2" daystars when I first got my truck and it sat level. Its really not a bad install, I did it in my driveway in 3 hours. take some fender measurements as you may only need the 1 and 1/2" spacers. I can find you part numbers if you need.
    00' RCLB 2wd 5.3 AT: Wheatley Tune, Comp 265H, 706's milled .025, Comp PR's, 918's, Efans, s&b CAI, AEM lt's, magnaflow, ASP UDP, circle d 3200, 4.30's currently down awaiting built lq4
  3. #13
    Union, MO
    When you say "take some fender measurements" do you mean from the rear? From the ground up to the wheel well?
    2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
  4. #14
    Kansas
    ya from the ground to the bottom of the wheel well arch. You will get some sag so you never get a true 2" but very close
  5. #15
    pasadena tx
    well some have torcion bars i have a tahoe and my friend has an 05 ex cab and ut has torcion bars if it does just crank them up and there goes ur truck will be level and if it has springs just go 2'' and it will be level....
  6. #16
    Union, MO
    Thanks guys!
  7. #17
    Indy
    Medic2967
    I have an '04 4x4 ECSB, and I have as some have mentioned TB's up front. I just put 2.5" of front end lift by installing some new TKeys, and it looks pretty good, since yours is 2WD, it may not need to be lifted as much. If you have springs up front, just measure the distance from the ground to the fender in the rear and determine how much will be needed in the front by measuring that same distance you obtained in the back...of course this is assuming that the Tire/wheel combo will not change. The spacers are pretty easy to install! Either way...just do it, you can always take it back out if you don't like, but I'm guessing you will!
    '04 Black Chevy Silverado LT Ext Cab Z71 4x4
    Westin SS Step Bars / Lorado Tonneau Cover / Rhino Liner / Suspension Maxx Leveling kit / Hankook 33x12.5x16 MT Tires / Mickey Thompson Classic II 16x10 / 3" PA Body Lift / AEM Brute CAI / Chrome & Carbon Fiber-like Grill w/ Red Bowtie / Dual Cat-back with Flowmaster muffler
  8. #18
    Kilgore, TX 75662
    my 05 ecsb 2wd has coils.
    I've been tempted to lower the rear of my truck, but I think it looks strange when you have a bunch of weight in the back or are towing a trailer and the back end is REALLY low.
    I think the OP should measure from the top of his wheels to the fender front and back and then take the difference.
  9. #19
    Quote Originally Posted by AdioSS View Post
    You could lower the rear end and buy the Airbags that are designed for towing (not expensive, no switches/compressor). It has an air valve just like a tire. When you have weight on the truck you can air up the bags to keep the truck more level
  10. #20
    Union, MO
    Now when you say there will be some "sag", do you mean a small amount in the front or back? Also, I've heard you have to replace the shocks due to the increase in height. Is this true or people blowing smoke up my ass?
